Spectra CU1485 Radiator
I recently installed the Spectra Premium CU1485 radiator in my 02 SS. This radiator was mentioned in another thread a little while back but wanted to start a thread just concerning it. It is the same core thickness as an LT1 radiator but has none of the normal ports that have to be blocked off. There is no heater hose port on the bottom left, no coolant level sensor hole below the filler neck either. It is basically a true drop in LS1 radiator with a 1.25" core thickness. It does have the automatic transmission cooler installed. Even though the CU1486 radiator is listed for LS1 cars that has all the normal ports that would need to be blocked off. Basically if you are looking to upgrade to a thicker core radiator with no hassle this is the best radiator I have found.
ill be ordering one! thanks man. Really don't wanna put lt1 parts in my ls car lol
Yes you order one for a v6 lt1 generation car then it doesnt have ports to block off and its thicker. I have a v6 rad in my procharged car. A new one I got a few years ago.
Forgive me if this is a question with a well known answer, but I don't see anything mentioned about this "thicker" Radiator being compatible with the stock A/C Condenser. Is this something I should be concerned about before buying one of these for my 1999 Formula? I will most definitely be retaining the Air Conditioning System and would like to know if both the Condenser and Radiator will fit in their stock locations without modification. Can anyone shed some light on this?
Also, the description of this Rad on Summit's site says it includes the Tranny Cooler for an Automatic. My car is a manual and I would much rather not have the deminished cooling capacity (I'm quite aware that its negligible) by having this cooler that won't be in use. Does Spectra or another manufacturer offer the same Radiator for a Manual Transmission early 4th Gen V6 car? Thanks.
The following users liked this post:
BODUKE (06-12-2020)
