tapping noise after intake install
Guys i have a tapping noise. Sounds like its towards the rear of the motor on the drivers side. I just recently installed a fast 102 intake and ls6 valley cover. When removing the stock intake i broke the opsu. After installing everything i heard a noise shortly after starting the engine, it increased with rpm. Pulled the intake...Found this:
I assume that is part of the inside of the opsu. i taped all the intake ports right after i pulled the intake so all i could guess is when the opsu broke all that **** fell in as i was pulling the intake.
I removed it. Put everything back together. Noise still there. Pulled the plugs on the drivers side. felt around with a magnet and didn't get anything. Pulled the valve covers, nothing looked suspect.
I Used a shop vac and turned the motor over a few times and it appears initially that the cylinders are still sealing. I could hear the vacuum go from intake to exhaust as i rotated the engine, and also i could tell when the valves were closed.
The tapping noise is still there but it does quiet up some when the engine warms up.
Any ideas whats going on?
Edit: damn i thought i was in the internal section
Craziest thing just happened. I drove the car about 15 miles to log some data and get help diagnosing the noise. By the time I got there the noise had stopped. Drove another 10 miles and the noise randomly started up again as I was about to pull in a parking lot. Scratched my head for a little bit. Started the car back up and drove home. Within 5 minutes of driving the car it stopped again. I don't know what the hell is going on.
noise is gone. dont know what it what. did some work on the AC vacuum line because i was only getting defrost and lower vents working. haven't heard the noise since fixing that. never thought a vacuum leak could make a noise like that but i guess its possible.
