a.i.r.removal
a.i.r.removal
guys, when you remove the a.i.r. system is there any vacum lines that have to be capped in order to have it idle ok.? and if there is can anyone tell me where there at and is there a step by step removel site.?
There is one line that needs to be plugged.
I followed these instructions when removing my air.
http://www.ls1camaro.net/sections.ph...ticle&artid=70
ok i read the how to but did not see which line needs to be capped?? i took my A.I.R. pump off like a year ago and never had a SES light that i am aware of, but on the drivers side near the fuel rail i have a reallyyyyyy tiny line that i have no idea what it goes to so i just push it onto one of the coil packs bolts....
If you get a chance ,when it is running,can you put your finger over it and tell if there is a vacum,or pull it loose from the coil pack and see if it fu##cks up the idle. thanks. this is what im really looking for.!!
