TSP y-pipe fitment issues
I tried just about every angle I can to get these to line up, and it's still quite a ways off. Am I doing something wrong (everything is still loose, so there is some play, but not near enough)? Hooker LT's into TSP y.
Make sure everything is loose including the header bolts while lining it up. Are you sure you have all the pieces of the y pipe on the correct sides and going the correct direction? Everything should bolt together without too much trouble.
LS1Tech Premium Sponsor
Put the rear jackstands under your axle tubes which will tuck your torque arm and driveshaft up out of the way where they belong. From there, it looks like you should have an easier time of it after you tuck each of those short pipes up nearer the body panel.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It looks like the first piece on the drivers side is turned the wrong way. Turn it where it angles Down and it should bring it in closer I had the same problem at first. I subscribed and will reply ASAP to help. Just FYI my drivers side is 4 fingers from the ground lol
Here's my thread on my clearance issues.
https://ls1tech.com/forums/generation-iii-external-engine/1580045-tsp-stainless-ypipe-help.html
I have Hooker LT & TSP cated y-pipe yes it hits every thing & was a pane to fit & had to cut some. i posted pix in someone else's tsp fitment post, if u want to look it up.. but hears a real quick what i did if it helps
after fitting it i got it all together but couldn't move the I pipe back far enuf to go on to the y pipe... so starting with just the y part on the cat back. I had to put the drivers side together first then into the y. slid bolth sides up on the headers as far as i could then slid pas side back in to the y part well poling back on the I pipe.
found the link
https://ls1tech.com/forums/generatio...ed-y-pipe.html
found the link
I have the same headers and the non stainless 2nd gen TSP oryp. I had some small fitment issues and had to assemble the rear pipes first. I put the short pipe on the drivers header and leave it loose so you can rotate it to fit. I also had to use a cheap rachet strap to slightly pull the header collectors together to get it started and that helped alot as the gap was too big. I wouldnt loosen the header bolts to do this as they need to seal to the heads before pulling on them. One good trip around the block and the header primaires will bend to fit whatever force is put on them when pulled together to install the y pipe. I also used a rubber hammer to bump it on and all was good. Never hurts to use penetrating oil to ease the install either. I see Hooker still puts the pass side o2 sensor bung on the wrong damn side. BTW I installed poly mm's at the same time.
I had some fitment issues with my Tsp catted y also. The big thing is to get the pipe of the drivers side adjusted right and assemble it from the headers back, connecting the I pipe last. I ended up having to cut a 1/2 inch of my i pipe. Also remember to keep all your clamps loose. The clearance isn't as good a I would have hoped but it defiantly helped.
Sorry, about the lack of updates, I've been busy. I was finally able to piece it together assembling the Y-pipe first, then fitting to the headers (thank for the suggestions, and great wife for helping me). I used a jack to put a little pressure on that drivers I-pipe, from a suggestion in the link 14k put up, and it tucked everything up nicely.
Here is a picture from when I dropped it off the jack stands. I'll take it for a drive tomorrow, see if it settles any lower, but right now I'm happy with it.
