Air / Egr Delete !! help the newb !
hey guy's...first off hey im new lol
second i know i did search but all the threads are old and the pics are no longer there !!! so don't shoot me
Car Is a 99 Z28
Ok anyone have pictures of what to remove ?
im ordering lt's with the ory pipe ...and need that stuff outta there !
thanks folks !
Car Is a 99 Z28
thanks folks !
The EGR is the ugly can-looking thing on the passenger head at the front. Everything connected to it goes, and if you're running an LS1 intake, you'll need to get a rubber expansion plug to block the EGR port on the intake. Advance Auto or Auto Zone should carry them.
Air lines, same deal, you'll see the lines you'll need to pull off when you start on the install. The air pump is driver's side front, behind the turn signal. Doesn't have to be removed, as it isn't too heavy and you can pull the fuse/relay for the air stuff (forget which it is), but it helps clean things up some with it removed.
