Blade and Boot slip MAFS
Ok, looking at cold air intakes and now confused...Looks like Spectre sells kits for SD/Blade MAF/Boot Slip MAF. I have read the info on SD, so I want to stick with the MAF.
A blade style MAF would make a install much smoother, but is that a stock set-up? I know my LS1 came with the boot in style, but the more I think about putting a 78mm MAF in a 92mm TB/ 102 intake set-up sounds like a choking point in the system.
Can I use a Blade MAF without much headache?
