EGR and A.I.R delete?
Hey guys, I'm looking into buying some 1 7/8 headers from Texas speed. The Texas speed headers don't have the EGR or A.I.R. My camaro is a 00 so it has EGR... What are the pros and cons of a EGR and A.I.R delete?
LS1Tech Premium Sponsor
They are only emissions, pros would be to clean up the engine bay (very small weight reduction), cons would be that you would need to tune them out (tune will be needed with longtubes anyway)...
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Most common method I've seen people use is an expandable freeze plug. Two washers with a rubber insert that expands as you tighten the nut. It has a larger washer on top in case it were ever to come loose to keep it from falling in.
We can get the pacesetter block off plate and gasket... Although since our headers do not have the emissions fittings, you will just need to remove the air tubes, remove the egr pump, and just plug the intake manifold.
__________________
