White smoke/Cold Startup
Old 09-27-2012, 09:41 PM
fbodyftw's Avatar
Default White smoke/Cold Startup
Hey guys, on cold start-ups i blow white smoke, more smokes blows when I'm leaving in reverse if I don't let it heat up enough. as far as i know no smoke just driving/wot. i just did my coolant flush, I've kept a eye on while started, no bubbles, it is a f13 cam, when i bought it was only driven about 200 miles in 2 years, with fresh royal purple but i have switched to Mobil 1, I changed the oil right away, looked fine little dark but normal. the smoke is not sweet, smells like burnt oil and the oil cap is a dark golden, i figured it was from the sitting oil not being used enough, the car runs great/drives great.
I have done a tune up, plugs wires, filter, cleaned maf, I still need to install my pvc valve.
What are you guys thinking this is?!
Old 09-27-2012, 10:15 PM
Sales1@Texas-speed's Avatar
Hmmm. If your thinking its possibly oil smoke I would pull the valve covers and take a look at the valve seals. Could just need a set of new seals to cure your problem.
Old 09-27-2012, 10:57 PM
Sladester2's Avatar
Do you have cats? How much smoke are we talking about here?
Old 09-28-2012, 12:27 AM
fbodyftw's Avatar
Seems to be more when it sits longer but if cooled off for a while just puffs for a couple of seconds
Its starting to get 40-50 in mo. So it may affect it more
Old 09-28-2012, 12:28 AM
fbodyftw's Avatar
No cats, tuned out.
Old 09-28-2012, 11:20 AM
Sladester2's Avatar
ya mines starting to when I first start it up here in the cold weather. Im in Missouri also. If it was a problem and oil, shouldnt it be doing it the whole time?
Old 09-28-2012, 12:24 PM
fbodyftw's Avatar
Where at in mo? And I though so to but I have good oil pressure and am only like a half quart every 3,000 but I drive like I stole it so I figured I would use oil.
Old 09-28-2012, 07:15 PM
Sladester2's Avatar
Farmington
Old 09-28-2012, 11:20 PM
1_MEANZ28's Avatar
Post up a vid
Old 09-29-2012, 03:36 AM
King Nothing's Avatar
if it were oil wouldn't it be blue not white? white smoke would indicate water or coolant in the combustion chamber wouldn't it???
Old 09-29-2012, 11:12 AM
Sladester2's Avatar
Ya thats why I mentioned him having no cats. Thats exactly what I was thinking
Old 09-29-2012, 12:21 PM
I agree with that statement. Its just weird he claims to smell burning oil maybe he is just mistaking the smell.
Old 09-29-2012, 07:01 PM
fbodyftw's Avatar
Well, I've started it and had no bubbles in the coolant, I should use a tester. I thought if it was coolant it would smell sweet, but smells like oil/gas mixed. I've noticed a burnt smell in the engine bay when driving for awhile.
Old 09-30-2012, 06:31 AM
i would think unburned gas in the CC would cause you to run rich and have black smoke . . . have you changed your oil and smelt the oil that came out of the engine itself? if it smells like gas you have a problem and shouldn't run it at all
Old 09-30-2012, 03:49 PM
fbodyftw's Avatar
I changed it two days after I bought it. Had a oil change but sat for about a year with only 200 miles on that oil, it looked fine/normal for sitting. I will smell the oil soon because im due for a change.
Old 10-01-2012, 03:10 PM
Remnant-of-VII's Avatar
I think your car's probably fine. I'll get a steady stream of white smoke on a cold start all the time here in Texas. Especially during the fall/winter seasons. Did it with and without my cats. More than likely, the smell is just a bit of unburnt fuel from cranking. The smoke is just condensate.
So relax and enjoy your new ride.
Quick Reply: White smoke/Cold Startup
