O2 sensor confusion...Help
Old 09-28-2012, 09:07 PM
badazz81z28's Avatar
Default O2 sensor confusion...Help
Ok, Looking to buy O2 sensors for my swap. I have a PSI harness and the connectors look like this:
But when I look up the 2002 Camaro O2 sensor the connector looks square...Is that just a file photo or is the camaro sensor not what Im looking for?
Old 09-28-2012, 09:10 PM
moeZ28's Avatar
The second pic is the actual pic of a 98-02 LS1 O2 sensor, looks like a Bosch. It is definitly a square plug in.
Old 09-28-2012, 09:18 PM
LS1WS6dreamer's Avatar
[/QUOTE]
Yeah this pic is the connection used on a f-body or corvette C5 rear sensor. IDK about the top one....maybe try C5 front sensor on rockauto or GM truck to get a pic.
Old 09-29-2012, 01:34 AM
94'BLKBRD's Avatar
Contact PSI about your harness??
Old 09-29-2012, 08:14 AM
DirtyDirk's Avatar
Look up a pre-convertor o2 sensor and see if it is flat. I'm sure with the PSI harness you don't use the post-convertor o2 sensors which it looks like what you looked up.
Quick Reply: O2 sensor confusion...Help
