tb question
tb question
I know there is a difference between a 98 and a 2001 tb, the 98 is more rounded vice oval, but can I run a 2001 tb on a 98 car or is there other stuff that needs to be changed like the cable?
I'll swap a 98 throttle shaft for your 00+ shaft, that way it will work right. You would need to program the computer or something to adjust for the different throw of the throttle shafts.
PM or email me if you need to swap shafts. I'll even half the shaft for you and send it with short blade screws.
Scott
Scott
