Wire mod done... what is this for???
Old 10-04-2012, 07:23 PM
Blownbayou's Avatar
Default Wire mod done... what is this for???
Done the wire mod (thanks to the write ups) and I broke the two way check valve.... even when I got warned in the write up
Going to oriellys tomorrow to get the dorman 47150 replacement and was wondering.... What is that thing for???? Reason asking, when I was taking off the other lines, the line to the firewall came loose (grommet pulled out) but it still feels tight. If I in fact pulled the line from wherever it goes in the cab, where do I look for this???
Thanks Again
Old 10-04-2012, 07:32 PM
k_garretson23's Avatar
its a vacum line. I believe it has something to do the the hvac system. Not positive though
Old 10-04-2012, 07:36 PM
BennyB's Avatar
Vacuum to hvac venting, you are correct
Old 10-04-2012, 07:37 PM
Blownbayou's Avatar
damn... I hope I did not pull the line. Thanks for your input
Old 10-04-2012, 07:40 PM
Blownbayou's Avatar
what would the symptoms be if I did pull the line.... Engine miss??? Gotta wait til tomorrow to get the valve.
thanks
Old 10-04-2012, 08:00 PM
CHADsterss's Avatar
If you pulled the line you'll be able to turn your ac on but it will only blow at your feet, no matter what setting you choose you won't be able to get the air to come out the dash vents.
Old 10-04-2012, 08:02 PM
Blownbayou's Avatar
Appreciate you my man..... great info for sure!!!!
Old 10-04-2012, 08:21 PM
CHADsterss's Avatar
No problem! I had a problem with one of those... I kept putting it off the finally after a month I was looking for the problem and one of those tiny hoses came off the back of my intake. Such a simple fix.
Old 10-05-2012, 11:57 AM
astro11271984's Avatar
Same thing happened to mine simple fix but get ready to tear some skin reaching back there with the cowl teeth
Old 10-05-2012, 08:22 PM
joecar's Avatar
Clip the sharp points off the cowl pins.
Old 10-05-2012, 10:18 PM
oldmano2z's Avatar
yeah,clip em . i found out the hard way ,,gouge,cut, scrape....
Old 10-05-2012, 10:22 PM
Blownbayou's Avatar
thankfully the hose/tube did not come undone.... replaced and cranked it up. Air out the vents.... thanks again
Old 10-06-2012, 03:57 AM
CHADsterss's Avatar
That's good! And yes those teeth on the cowl are painful!! I've had my fair share with them haha!
Quick Reply: Wire mod done... what is this for???
