Throttle body help!!!!!!
I have a nick Williams 92mm throttle body and I need the metal tube that goes into the left side over the linkage that runs into the pcv system anyone know where I can find one????
So did you find it, or did you get a brass one from a hardware store?
IMO, Get a 1/8"npt to -6AN adapter then use a female -6AN 45* to -6AN barb fitting and go right over the top throttle cable/cam. That how I did mine except with a -6AN 45*hose end and there's no clearance issues at all with the throttle cable/cam assembly.
http://i523.photobucket.com/albums/w...fitting004.jpg
