ls conversion
ls conversion
im new here, i'm putting a 2006 5.3 truck engine with DBW in a car,changed intake to a older style ls1 my question is that the intake will sit down on the engine but the throttle body will not bolt up because it hits the water pump outlet and the idler beside the alt. what do i need to get or do to make this work trying to keep the alt,ps bracket or do i need to get a different bracket. will the injectors interchange from the truck to the ls1 intake without having to mess with the wiring or changing plugs. thanks
