fast 102 couplers?
Old 10-29-2012, 11:37 PM
sdimex's Avatar
Default fast 102 couplers?
so i bought a fast 102 intake and throttle body for my ls swap . its a 102mm id tb so it is 4.25 od . i need a 90 degree coupler that is 4.25 inch id and cant find them any where . is any one using a 102mm tb and what coupler are you using .where did you get them?
Old 10-29-2012, 11:52 PM
garygnu's Avatar
try air flow systems .
Old 10-30-2012, 07:06 AM
dmaxvaz's Avatar
Intakehoses.com
Old 10-30-2012, 05:52 PM
sdimex's Avatar
they only go up to 4 inch
i need 4.25 inch
Old 10-31-2012, 09:34 AM
sdimex's Avatar
bump , any one using a 102?
Old 10-31-2012, 02:40 PM
99Bluz28's Avatar
Intake hoses.com does have a 90 degree 4.25" to 4" ID Silicone Reducing Elbow(R90B-400-425SR). I have found larger 90* elbows but they start at 4.5", no 4.25".
Old 11-02-2012, 08:01 AM
bryanracing95's Avatar
Silicone Intake Systems 90 deg works fine on my NW 102, i have the 4 inch its flexible so it will fit right over
Old 09-05-2018, 12:17 AM
lccreech's Avatar
https://www.intakehoses.com/silicone...oss-black.html
Old 09-05-2018, 09:25 AM
Full-Force's Avatar
i need 4.25 inch
No, you need 4". 4" will slip right over a 102 throttle body. Not to say you cant squeeze a 4.25" coupler down with a clamp but the 4" coupler is perfect
Old 09-05-2018, 09:30 AM
Full-Force's Avatar
i need 4.25 inch
No, you need 4". 4" will slip right over a 102 throttle body. Not to say you cant squeeze a 4.25" coupler down with a clamp but the 4" coupler is perfect.
This is my 102mm setup using a 4" coupler
The following users liked this post:
spectre977 (09-04-2022)
Quick Reply: fast 102 couplers?
