Just installed motor and t56 and
I go to crank it and its a big GRINDDDDD!!!!! at first it turned the motor over but didnt turn on.... now its just grinding.... I have switched 3 starters already so its not the strarter... the flywheel looks good from what i can see... what can be causing it to grind? I about to pull the trans out and try re-installing clutch ... but Ive never had a issue with it.
Any help is greatly appreciated
pulled bellhousing and clutch off.... Looks like the clutch was not installed correctly .... cause the trans was a B**** to seperate from the bellhousing..... and the "new Pilot Bearing" is trashed..... Im assuming my helper was not aware how to install a clutch.....But took the starter to Vato Zone and exchanged it for a new one... time for attempt 2
