LS6 Intake..how to fix
I just noticed that my LS6 intake (came with the car when I bought it - uninstalled) has a small chunk of plastic that is missing right beside the gasket for the throttle body. Not sure if it's a big deal, but I'm picturing that it will cause a vacuum leak and possible allow debris directly into the engine.
How do I fix this?
How do I fix this?
is that chunk just missing on the inside of the intake bore?
or is it on the outside also?
im gonna say if its just on the inside, i wouldnt even try to repair
it for fear that a piece of the "repair" would break off and get sucked
in...id leave it, and run it, the torque from the throttlebody should smash
that gasket enough to seal.
Yeah, I figured that it should still seal up pretty good. I was also concerned about the repair flaking off and getting sucked inside. Maybe better just to not mess with it and just install as is!
Thanks.
Installed it a few weeks ago, even after breaking one intake manifold bolt and re-using gaskets (GM dealer wanted $172/set!!) I have no vacuum leaks or other issues! I did break the opsu which sucked, but I got the intake for free with the car so you win some you lose some. Noticeable difference, especially with the larger 98 cam and long tube headers.
