cant take off the pulley bolt.. keeps spinning in all gears.. a4.. pls help!
i crank on the.. crank pulley bolt, and it just spins.
i tried park, first, drive, neutral, e brake with all, reverse.. nothing.
i got this idea of trying to start the engine with the wrench in there,
but a friend said toyota techs did it and one broke his hand on a <100hp engine so dont do it.
another idea was to jam something into the flexplate (everyone calls it "flywheel"?) to stop everything from moving. but then a friend said it might mess up the balancing or i might break something.
all i want to do is to swap these pullies,
but the TC is mush and spins easily.
LS1TECH Sponsor
Originally Posted by Stone0fFire
OH MY GOD WHAT A PILE OF CRAP NEXT TIME I AM GETTING AN M6
thanks for the info, ferocity.
be back.. going to to auto parts store.
9 Second Club NA
Dont know if you have an air compressor and an impact, but if you do, you could save your self the hassle and the time and get it done within a few minutes. Cant remember off the top of my head what size the head is, but if you use an impact, youll have it off within seconds. If its the stock pulley, then a 3 jaw puller will take it off, but if its an ASP, then a regular puller will work, you just need to screw the 3 bolts into the pulley. I believe theyre metric threads.
