Different exhaust question - Modify Magnaflow cat-back?
Old 11-15-2012, 12:42 PM
The_Bishop's Avatar
Default Different exhaust question - Modify Magnaflow cat-back?
I'm not really liking the magnaflow cannon tips on my car. I saw a 3.5" mufflex system locally for sale, but it has the spintech muffler everyone says flows like crap.
Now I'm debating just ordering a magnaflow 3" bullet muffler and the necessary 3" stainless bends, and making the magnaflow setup a 3" single on the left. This way I'd end up with a stainless exhaust, the tip could be tucked carefully away.
Anyone do this? It should be the same (possibly better) flow as the cat-back magnaflow, but without the huge tips.
Old 11-15-2012, 06:22 PM
VinR1's Avatar
Why not just cut the cannons off and clamp on some cheap turn downs? They're only like $12ea at most parts stores...
Old 11-15-2012, 06:34 PM
The_Bishop's Avatar
Because then they'd still be hanging down? Also, there are support brackets welded to the cannon tips.
Old 11-15-2012, 06:35 PM
03Sssnake's Avatar
I am actually running the spintech TOTL/2OTL, not sure about flow. I think it sounds pretty damn good though. I am using GMMG/Mad Hammer slash-cut tips FWIW, had them laying in the garage. The slash cut tips that come with the system are a little larger, not by much, I just happen to like the GMMG/Mad Hammer tips better.
Old 11-15-2012, 07:32 PM
VinR1's Avatar
Unless your piping is welded to the muffler, you can loosen the clamps and point the tips up slightly (once you cut the tips off) - see pic 2
The two rear hangers are there to support the weight of the tips. Once theyre cut off, just unbolt the frame brackets and sell 'em with the tips (I got $60 for mine). The front passenger side hanger is welded to the over-the-axle pipe and the driver side front hanger has about 2" of pipe after it before the tips - if you cut at the right spot, you keep that hanger and have plenty of room to clamp turn-downs - see pic 1
Old 11-15-2012, 07:37 PM
The_Bishop's Avatar
Hmm. I'm going to have to get it up on jackstands tomorrow and look at it better.
Quick Reply: Different exhaust question - Modify Magnaflow cat-back?
