melted rattling catalytic convertors again .advise please
Old 11-23-2012, 06:49 PM
steves2002z28's Avatar
Default melted rattling catalytic convertors again .advise please
I melted 2 cats this yr .in the spring I wanna cut cats off .do I need to tune out rear o2s. Also my set up on my 99ss is long tubes with corsa cat back. Will car get louder
Old 11-25-2012, 09:43 AM
nomasterase's Avatar
if you dont want to deal with a service engine soon light you will need a tune to get rid of the rear o2 codes or at least some o2 simulators and yes it will be slightly louder
Old 11-25-2012, 12:08 PM
Cool thanks
Old 11-25-2012, 03:23 PM
Pontiacerator
RevGTO's Avatar
I hope you solved the problem that led to the melted cats - running super rich?
Old 11-25-2012, 04:53 PM
I don't have any check engine lights or anything n exhaust guy said I must b running rich when I put new cat on 5months ago I'm gonna change plugs n clean maf. Car don't smell bad n fuel econemy ok.
Then cut off 2 bad cats n get tune .hopefully that helps .thanks again
Old 11-28-2012, 12:12 PM
Droptoplt1ta's Avatar
CATS will melt from a RICH condition, cylinder missfires, or coolant in the combustion chamber.
Old 11-28-2012, 06:06 PM
LilJayV10's Avatar
I was going to say the same things. Removing the cats is not going to fix the problem that's making them go out.
Old 11-30-2012, 02:04 AM
chevybayboy's Avatar
Try putting real time scan tool on it the sell them on eBay called torque it Bluetooth to your phone turning it to a hand held live scan tool its a great deal for 33 bucks it also let's you clear check engine lights afr and a lot more
Old 11-30-2012, 03:06 AM
Jontall's Avatar
You don't want cats on any high performance car so unless you live in California, get rid of them.
Quick Reply: melted rattling catalytic convertors again .advise please
