bad fuel?
pour some Stabil fuel stabilizer in there, bounce the back of the car to mix it all together, and start it 15-20 min after that. it may sputter a bit or start hard, but it will run fine after that. i would take it easy and keep it under 4K RPM's till you get some new gas in there. run the tank down to the E before filling up with new gas.
I have only seen bad fuel make a car run bad in extreme cases where the fuel was either extremely old or contaminated. I doubt it will cause the car too run for 2 seconds and die out every time.
Yea I noticed when I poured the new fuel in I got it to run and idle by itself for 1
Min then it died trying to get all the bad fuel out of the lines I unhooked the hose that goes to the fuel rail and and got almost all of it out put a few clean gallons...how long do you think it might take to get the rest of the bad fuel out
