quick coil ?
Found this on ebay...
Check out the description below, in the ad...says that 97-04 Vette, & 98-03 Camaro are compatible.
Part #12558948
http://www.ebay.com/itm/01-Corvette-...51188536833%26
Part #12558948
Part #12558948
Part #12558948
LS1Tech Premium Sponsor
The coils were the same mounting even for the perimeter bolt headed cars...just the cover and brackets changed!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
For those you will have to have the coils, brackets, and harness and to my knowledge the brackets won't bolt to your valve covers. There are 2 different kinds of them as well, square ones and the more desirable cylinder shaped ones with heat sinks on them which are "hotter".
I would just replace the bad coil and worry about swapping when you put better heads on the car that require you to go to the bracket mounted coils anyway. If you are looking for a power gain, there will be none however some people report slightly better throttle response and idle but on other cars there is no difference.
