Ngk tr6
Old 11-30-2012, 01:40 AM
chevybayboy's Avatar
Default Ngk tr6
Are these good plugs for a mild build there on eBay for 19.99 for a set of 8 is that a good dealas well
Old 11-30-2012, 04:07 AM
bww3588's Avatar
Decent price...tr6's are generally for higher compression engines as the heat range is colder. Unless your changing compression to 11:1 or higher, I would stick to 55's or an equalivent
Old 11-30-2012, 09:59 AM
Ok so the ngk 55s?
Old 11-30-2012, 12:17 PM
Roarin_8's Avatar
Aren't NGK TR6 plugs for nitrous use and TR55 for N/A use? That's always what is usually posted.
Old 11-30-2012, 12:20 PM
03Sssnake's Avatar
^^^ Yes the TR6s are step colder, you use them with nitrous, used them in my 03 cobra when I dialed up the boost (2.8 pulley)
Old 11-30-2012, 12:33 PM
Ferocity02's Avatar
TR6's are widely used in boosted applications too. 55's seem to be the go-to plug for NA and normal compression.
Old 11-30-2012, 12:40 PM
HCI2000SS's Avatar
Not to steal this thread, but I have these plugs and they are gapped at .042. Do any of you know if that's acceptable for spraying a 100-150 shot at?
Old 11-30-2012, 01:29 PM
97camaro383's Avatar
Id look at getting some Br7ef plugs, I was running tr6s and they werent cold enough for the 150 shot and melted. May of cost me a motor
Old 11-30-2012, 01:38 PM
HCI2000SS's Avatar
Oh wow!! Thanks for that info, i'll definitely consider some different plugs then lol
Old 12-01-2012, 07:13 PM
Mez
Mez's Avatar
TR55 are made for .055" gap. If you want to gap at .040" then get TR5. Don't gap the TR55 down to .040".
Old 12-01-2012, 08:12 PM
I just went ahead and got ac delco iridium
Quick Reply: Ngk tr6
