Milled 243 heads questions.
Hello guys I came across a set of LPE ported and milled heads on Craig's list. They are milled .070 and I was wondering if they will work with my tape torquer v2 without flycutting the pistons.
.070" is an *** load to mill 243s! You would have probable PTV clearance issues a .025-.030...Nothing would fit at .070"
Sure he didn't mean .007"? If that case, you should be fine. But you need to check anyways.
You're not going to flat mill an ls head much more than around .050 or so before it becomes too thin for comfort. Angle milling is a different story. But I bet you know nothing about that. If you're going to talk about things like that and refute credible limits of a common individual, you need to make that clear. Not spout off about how your setup is running on the ragged edge of disaster and all is well because you got away with it.
You also have to consider you're not only cutting the deck so thin you may have sealing issue (or cracks/leaks), but your also talking about cutting the pistons to a unsafe level too. I'm not sure how thick the head of the piston is, but I doubt its that thick.
What fuel is the OP trying to run? Not sure what the compression comes out to be...even with a stock MLS gasket, its above 12-1
What compression do you get with at much milled off? You are running pump gas??
