TB coolant bypass ?
TB coolant bypass ?
I'm doing a swap right now and I'm running the stock mustang rad. I don't have a coolant hose to even run the coolant through the tb. What are my options? Can I remove that crossover tube from both heads and block them off and just cap the tb lines? Thanks
DO NOT BLOCK OFF THE LINES FOR THE HEADS! They are needed for steam expansion for the cooling system. The throttle body coolant crossover can be delete without any problems unless you plan on driving it in super cold weather. It is meant to keep the throttle plate from freezing.
