Fixed ticking !!! Take a guess??
Well I finally fixed the ticking I had after installing Hooker LT's....This ticking was bugging the crap out of me.. ...So after so much looking and wondering and searching posts about ticking.....I finally was about to give up ...so I went on and jacked up the car to fix banging issues with the Ypipe and while under there I glanced at the wires again and one of them looked odd.....The boot wasn't all the way in..so I tried to push it in and but it wouldn't go any further to a snug click fit....So i was like WTF!!!...I removed the taylor wire and replaced it with a stock wire to see if the wire was the problem...I replaced it and the ticking was still there only not as loud!! ..so I thought ..ok...we are on to something...So while replacing the stock one with another taylor wire (different location)...While feeling for the spark plug tip...I felt the tip of the plug kind of loose!! ..I had no idea those tiny tips could screw off.....So I tried to tighten it and the whole plug felt loose.. ...I was like WTF......So I removed it and rescrewed the tip back on and replaced the plug only this time tightening it down for sure!! ..after that the wire went all the way in and snapped on with the click....started the car up and no ticking whatsoever!!!!!!!!
so it was a loose spark plug witha loose tip...
I ws so relieved especially after reading so many posts with so many possibilities ,rockers,lifters..ugh.....
It would be wise to recheck and double check everything you do especially when you do headers... ..cause you can easily forget the most simplest things.......
What the hell!
First piston slap, then the sqeaky tensioner pulley, now I have to worry about sparkplugs falling out of the engine.
EDIT: Thanks for the post though, you may have solved my problem.
1 Post
During my H/C install I found 3 plugs that were very loose, and about 5 of the tips had to be tightened also.
So it would be a good idea to check your plugs once every month or so. It doesn't take too long.
Originally Posted by Chad01Z28
Wasn't throwing an SES light with the spark plug loose? I have the same ticking, guess I need to check the plugs out. Thanks for the info.
I had the same problem. The ticking was driving me crazy. A GM tech told me this is normal. Right. I listened as close as I could without burning my ear off and it sounded like it was comming from the manifold. I decided to check the plugs and one was so loose I could twist it with my fingers! Tightened it back and the car sounded perfect.
LS1TECH Sponsor
Mine spit out a plug a few years ago. It was a factory installed plug as well. Going down the road one night and had a strange underhood noise then SES light. Pulled over to see what it was and the number 5 plug was gone. 3 others were loose. That night sucked. I check them from time to time now.
