where do i find 02 camaro exhaust manifold / header bolts
Old 12-15-2012, 02:31 PM
djrowe007's Avatar
Default where do i find 02 camaro exhaust manifold / header bolts
I am pulling off my exhaust manifold bolts right now, every once in a while my socket slips the bolt and is starting to strip. I know I will be able to get them off but are there any places where I can look for stainless bolts or just replacement bolts for backup?
They are 10mm on my car... I have searched.. can't find replacement bolts except for the local dealer.
Old 12-15-2012, 04:43 PM
2000PewterT/A's Avatar
Most of the sponsors on here should have some header bolt kits. If you are doing headers I suggest some sort of locking fastener like a stage 8 head bolt kit.
Old 12-15-2012, 04:55 PM
senicalj4579's Avatar
ws6 store for header bolts and just fyi the heads on the new bolts are bigger than old stock ones. I used them and they are great.
Old 12-15-2012, 04:57 PM
badazz81z28's Avatar
I have some stock manifold bolts. I switch to headers. Let me know if you have interest
Old 12-15-2012, 05:16 PM
djrowe007's Avatar
Senicalj4579 Is the thread bigger or just the bolt head? Do most people put new bolts in with new headers? I just ordered some kooks LT's they should be coming soon...
Thanks badazz81z28
Old 12-15-2012, 05:19 PM
Originally Posted by djrowe007
If the aftermarket bolts are bigger then I probably will stick with the stock ones because I am doing this from my garage don't have a way to enlarge the existing holes. Do most people put new bolts in with new headers? I just ordered some kooks LT's they should be coming soon...
Thanks badazz81z28
Most headers come with new bolts (They should). The header bolts are the same thread/pitch as OEM they just actually shorter than OEM bolts.
Old 12-15-2012, 05:24 PM
How many should there be?
Attached Thumbnails where do i find 02 camaro exhaust manifold / header bolts-bolts.jpg
Old 12-15-2012, 05:31 PM
djrowe007's Avatar
Well I hope Kooks all mighty would put some in there for me then. I believe there was 12 that I took off. I stripped 2 of them a little bit and I would be nervous putting those back on. Been waiting on these suckers to come since black friday. Kooks true duals too !!!!
Old 12-16-2012, 01:08 PM
TheSilverOne's Avatar
a 6 point socket wouldn't strip
Old 12-16-2012, 08:56 PM
Thanks badazz81z28
The heads are bigger. Threads are fine.
I had to buy a new set so I ordered from ws6 store. They got here and the heads were bigger. I called ws6store and they told me thats what they sell for the lsx motors now. They work fine.
Also, IDK what bolts come with every brand header but if they are anything like pacesetter header bolts then dont bother. Use stock bolts. I would prob always use stock bolts anyway.
Old 12-16-2012, 09:04 PM
You def don't want to use exhaust manifold bolts on Headers. They will surely bottom out. The heads on my header bolts are like 12mm vs the stock 10mm.
Old 12-16-2012, 11:04 PM
soundengineer's Avatar
go to lowes.. buy some
or order from McMaster Carr
or you can get them from summit racing
http://www.summitracing.com/search/d...ize/8mm-x-1-25
m8 x 1.25mm
25mm long
you may be able to use a longer bolt as well, I dont know how deep the heads are threaded off hand... but stock length is 25mm
Old 12-16-2012, 11:08 PM
m8 x 1.25mm
25mm long
My manifold bolts are 30mm UHL. 20-25mm sounds right for headers.
Old 12-16-2012, 11:10 PM
there you go... so a 30mm length will also work...
Old 12-21-2012, 10:28 AM
I actually have washers with stock bolts on the current car with ARH. Couple years ago I had pacesetters on the car which I used washers with stock bolts as well.
On my 98 I used stock header bolts with no washers with dynatech and the bolts were not to long.
Old 12-21-2012, 12:40 PM
djrowe007's Avatar
haha they did come with new bolts, ok i was just planning ahead because I had no idea. Thanks guys.
Quick Reply: where do i find 02 camaro exhaust manifold / header bolts
