102 TB clearance issues
I purchased a Ebay TB and the IAC hole does not match up with my sensor. I am returning that and probably going to pick up a Nick Williams TB. I was reading and saw some clearance issues with the water pump and other items that can affect the 102TB install. Is this common or is it only certain years? I am using a PP 96mm intake. Would I be better off with the NW 95mm TB then for it? Would there still be clearance issues with the 95mm TB? I was just hopping for a direct bolt on without issues. I really dont want to deal with grinding down my water pump pully..
54Kmile 2002 Camaro SS.
Couldn't resist....Yes there is a 2010, 2011, 2012 and a 2013 F-body.
But really on the new style pump? I'd never seen that before, but it's not like I look at the water pumps when I look at an engine... Really, though?
https://ls1tech.com/forums/generatio...02-thread.html[/QUOTE]
That's actually my pic of my water pump up there... Here are a couple of others that may help. These are actually new LS1 water pumps, not LS2 as I previously thought. The difference is the length of the snout on front.
Her are some pics from the same angles and the rear...see, no bolt hole to grind down.
