ASP Pulley Belt sizes?
Old 04-15-2004, 10:35 PM
TexasVortexx's Avatar
Question ASP Pulley Belt sizes?
I recently obtained a used ASP crank pulley and need to know the new belt lengths/part numbers for the new pulley?
Old 04-16-2004, 12:19 PM
Cokeroker's Avatar
straight from ASP. It has the belts required listed in the small print in the instructions. I believe I heard someone say that they were able to get them at Autozone.. not sure about that though
ASP recommends that this installation be done by an experienced mechanic.
1. Loosen alternator nut.
2. Remove 6 rib accessory belt.
3. Remove 4 rib AC belt.
4. Remove harmonic balancer bolt. Use 3 prong puller to remove factory balancer.
5. Lubricate shaft before of underdrive harmonic balancer and install. Lubricate area of pulley where bolt will contact pulley.
6. Apply Loctite to factory bolt and install. Torque until pulley is bottomed out or torque reaches 240 ft/lbs.
7. Loosen bolt and retighten to 37 ft/lbs. tighten another 120 degrees.
8. Install new alternator pulley (if supplied) and nut.
9. Reinstall belts as follows:
Accessory Belt w/ crank only: Gates K060760 AC Belt K040378
w/ Crank & Alternator Pulley: Gates K060770 AC Belt K040378
If using overdrive alternator pulley, Install Gates K060755 & A/C Belt K040378.
Old 05-08-2004, 12:04 PM
Scalpel's Avatar
That is incorrect. It should state, remove bolt and install a NEW crank pulley bolt and torque it to 37 ft/lbs and then twist it to 120 degrees. Please do NOT re-use the used stock bolt to do this. All of the other steps are correct.
Old 05-09-2004, 10:27 AM
PREDATOR-Z's Avatar
What he said, agreed.
Quick Reply: ASP Pulley Belt sizes?
