bbk underdrive pulley owners come in!
Old 01-12-2013, 06:53 PM
Sail Hatan's Avatar
Default bbk underdrive pulley owners come in!
Just picked up a bbk underdrive pulley for my cam swap, and it came with the alternator pulley. Car is an auto. Any way I can skip using the alternator pulley? Also I'm gathering its a 77 inch belt with the pulley on the alternator, so what's it with the stock alt. pulley? Thanks guys. I tried a search but got like 12 different options.
Old 01-15-2013, 07:01 AM
mjs1012's Avatar
I'd use the alt pulley. It'll turn the alternator at a normal rate of speed not slower.
Old 01-15-2013, 07:09 AM
Sail Hatan's Avatar
Ok, so it says it uses a stock belt? Is that incorrect?
Old 01-15-2013, 07:29 AM
LS-ONE_DAY's Avatar
I haven't looked into UDP's much but I know for an auto you want to use the overdrive pully for the alternator to keep the battery charged. You need a new different belt with a UDP so I assume you would still need a different size with the UDP/ODP combo. Info I found from a quick search:
SLP pulley response
Originally Posted by BaddBird
Originally Posted by LS1-NAVY
i bought the same ud pulley and i ordered my belts from thunder racing great guys and ship fast
Requires 2 new belts (Gates #K060763 and #K040378 or equivalent, not included). For LS1 F-Bodies only.
Should be able to get them at any parts store with these #s.
Powerbond 25% pulley
Originally Posted by dr_whigham
Cross reference these part #'s
6pk1915 - Main Drive Belt
4pk1015 - AC Belt
Just go to any parts store and they'll cross reference with whatever brand they carry.
Brand of pulley doesn't matter I imagine, if they are the same % of reduction.
If you don't want to use the ODP for the alternator your alternative solution to eliminate charging issues would be to raise the idle rpm. I believe 750-850 should be appropriate.
EDIT I just read on WS6Store's product page for the BBK pulley that it uses existing factory serpentine belt so go with that
Old 01-15-2013, 09:42 AM
mjs1012's Avatar
sounds right. the bigger alt pulley is compensating for the smaller crank pulley
Old 01-16-2013, 07:02 PM
JRENIGAR's Avatar
^^^ correctamundo...
Old 01-16-2013, 07:09 PM
Sail Hatan's Avatar
Ok cool. Then I'll just make sure they install both. Does the bigger alt pulley act against the underdrive pulley? Like Rob hp?
Old 01-16-2013, 08:19 PM
JRENIGAR's Avatar
No, its secondary driven and a bigger pulley will turn the alt slower. Look at it this way: Bigger drive pulley adds speed and drag, bigger driven pulley slows speed and reduces drag. Think mens 15-18 speed bike, works exactly the same way.
Quick Reply: bbk underdrive pulley owners come in!
