help with coil packs
Hey guys so i have a 98and did thE ls6 top end conversion . My coil packs are now on coil bracks and center bolt stlye covers.i have now discovered that on 98 each coil is specific to what cylinder it should be on. I believe i may have mixed them up. Does anyone know how to tell in what order they go? Or how to tell?
Or.maybe i was wrong and all coil packs are the same idk what is wrong with my car. It keeps blowing out the valve cover gaskets om start up. Not always but when i do i get a poof of white smoke from crank case when i do.
It shouldn't. Heres the thing with pcv. I have ls6 valley cover. But the previous owner removed the black piece that makes it function as a pcv. So i put an inline pcv between intake and valley cover. It only does it while cranking car and its warmed up. When car is cold it runs fine amd idles. Car wont idle anymore once its warm.
Could it be i have to beast of a spring for my cam? I purchased a 1208x pac spring kit. Rated to .750 i believe. Thought it was less max lift until i actually looked it up. My cam lift is .595 and .644
