LS1 Accessory Drive Kit
I'm swapping an LS1 from an F-Body into an S10. I need the Corvette high mount alternator to clear the steering box. I will also be going with a high mount A/C setup.
I found this kit from Pace:
http://paceperformance.com/i-6485405...7-engines.html
Has anyone tried this kit? I know I need a Corvette harmonic balancer for alignment, will 12635649 work on my LS1?
Their site says to use certain Russell fittings with the P/S pump. Is that because they supply an aftermarket style pump?
I searched for a while before posting this, couldn't find much on this specific kit. Thanks.
I know your looking at the vette stuff but when I did mine, I had all the accessories from my fobody parts car and I bought the kwik performance brackets for the fbody accessories and switch it all over think it was like 300 can't remeber off hand, just another option could save a little bit of money
Holley makes some nice looking brackets also. You have to use a Vette p/s pump, truck alternator, and any water pump you want with matching spacer kits for the brackets. You also have the choice between using a 2 different ac compressors.
I went with the LS7 / vette kit on mine (gmpp 19155067) and it worked great. I couldn't access your link from my phone, but I know pace carries the non-AC version of the kit for just over 500.
Neither kit includes the crank pulley. However, I *just* bought a fluidampr 'vette pulley for my car, and will happily sell off my original when it arrives.
