Truck PS pulley
Truck PS pulley
I'm in the process of stripping down my new (used) '04 LQ9 for cleanup before installing it in my '67 Camaro. For the life of me, I can't remove the PS pulley from the bracket. The bracket is out of the car, alt is removed, but can't separate the PS pulley from the pump itself.
I sprayed it well with PB blaster and let it sit for 2 days and then tried pulling it with a 3 jaw puller remover with no luck. I hit it with heat and still no luck.
I actually ended up bending the back edge of the pulley, and now there's a little play in the pump shaft. I may need to replace the pump now. Are all truck PS pumps interchangeable?
