Fast intake and...
Fast intake and...
Im going to be getting a fast 92/92 here next month and my questions are 1 will the stock fuel rails and injectors work with the intake?
2- If the injectors will be to small what injectors should I get and will THEY work with the stock fuel rail?
3- Or am I SOL and will have to get new injectors and rails?
Car is an M6 heads cam exhaust
Thanks for any help/advice
The Scammer Hammer
Exactly. Everything transfers over; All plug and play. A dab of Trans fluid or oil on the injector o-rings before you install them and that's about it. No need to remove them from the fuel rail either.
Once you do cam/heads I'd be looking at a set of at least 36# if not 42's
