View Poll Results: which would you put on your car?
1 modded Magnaflow w/3.5" cutout
2
15.38%
2 modded GMMG/Madhammer w/3.5" cutout
3
23.08%
3 modded TSP Rumbler w/Borla
2
15.38%
4 TSP True Duals w/Sweet Thunders
6
46.15%
Voters: 13. You may not vote on this poll
Poll: Help me build my next exhaust....
it's time to make some changes to my 98 SS, things are getting kind of boring and i've got a little money to burn......i'm about to slap on a set of 243 LS2 heads, Ls7 lifters, and re-tune.....i have 1 3/4 Pacestters now, but might upgrade to 1 7/8 TSP's........basic bolt-ons and cam listed in sig, the rest of my current exhaust is a TSP y-pipe into a single 2.5" Thrush glasspack dumped before the axle (i'm sure it doesn't flow very well)......the car is basically a weekend driver with the occasional trip to the dragstrip......i did have TSP true duals and loved them, but i eventually got tired of the gas smell, loud drone, and interior rattling, so i recently sold them.....my TSP y is the latest design with the better merge, i plan on cutting off the 2.75" necked down section of the merge (choke point) and just using the 3.5" rear of the merge......so out of these four, tell me which exhaust you'd put on your car and why....also, any changes you'd make
1) TSP y with merge modified to 3.5"
3.5" intermediate pipe
3.5" QTP electric cutout
reduced back to 3" then over the axle to a Magnaflow #15684 catback
PROS: quiet, good flow, hopefully minimal rasp, can control loudness with cutout
CONS: ugly tips
2) TSP y with merge modified to 3.5"
3.5" Jones glasspack 18" length
reduced back to 3" then over the axle into GMMG catback
ebay Corsa clone tips
PROS: should sound badass, hopefully minimal rasp due to glasspack in i-pipe, cutout for the dragstrip, tips would look good
CONS: GMMG is heavy, expensive
3) TSP y with merge modified to 3.5"
Borla #40086 muffler as i-pipe
reduced to 3" over the axle into a TSP Rumbler catback
two 12" Classic Chambered resonators welded just before each ebay Corsa clone tip
PROS: should be a fairly lightweight system with deep tone, nice tips
CONS: no cutout for dragstrip
4) stop being a Nancy and go back to TSP true duals with a set of 2.75" internal Sweet Thunders dumped before the axle.....after all, it is just a weekend driver
PROS: ultimate sound, excellent flow
CONS: drone, interior rattle, and this time i'll have to weld in a set of hi flow cats to kill the gas stank
CONS: ugly tips
I would go with GMMG it sounds great but it is expensive. I Wouldn't worry about the wight because it is adding it to the back and it will help the cars weight balance.
I'd say your crazy for ditching the duals in the first place. I went through 2 catbacks and battled rasp with both before doing the right thing. Although my duals are ran out the back so interior rattle and the smell of gas is not an issue.
http://madhammer.com/pages/mad_hamme...2-02_cama.html
I just noticed you had madhammer listed, but it is a good $200 cheaper than gmmg
i know what you mean, the rasp from their system can be horrible if you bolt it on behind LT's and ORY.....that's why #2 has an 18" glasspack welded into the i-pipe......hopefully that along with the widened merge would be enough to tame the rasp out
