worth switching from 85mm to FAST92
im currently running a 85mm intake and tb with all the mods in my sig. i will also be running nitrous this year. i know the 85mm is better then the ls6, but the 92/92 setup is better then the typhoon.
...but...is the FAST setup better enough to justify the $5-700 difference of buying a 92/92 then selling mine?
Once I went 92/92 I never looked back. If you can sell your throttle body/intake combo for 300 or around there and pick up a used fast setup for 800 I'd say go for it. 500 bucks for a 92/92 is definitely worth it in my opinion. Plus it looks so much better than the typhoon
Well then I guess you answered your own questions. Performance gains from a 92/92 aren't all that incredible when upgrading from a stock ls1 intake. I don't see how you'll benefit from trading the typhoon setup considering its only another 7mm...
There is also a lot more to intakes than the TB opening size. I wouldn't be the least bit shocked to see a Fast 78mm intake make the same or slightly more power than an 85mm intake due to overall better runner design and plenum volume.
If it was as easy at bigger TB openings, FAST would have some serious competition in the low profile lsx intake market by now.
Moderator
I think the front orifice is not that significant and the
quality of the runner design is everything. People talk
bad about the Pro Products intakes but I haven't seen
a direct flow-bench or on-motor comparo.
You could be the first!
