2 Ground "straps"
2 Ground "straps"
Hey,
I'm putting my engine back together and I wasn't able to see where these two ground straps go. Can anyone help me out?
1. Ground strap on passenger side of the engine off of coolant plug. It's next to the throttle body.
2. Ground strap that I'm nearly 100% sure it goes on the drivers side, lower block ground strap.
Thanks you for the help.
I believe that is actually a conductive heater for the PCV valve (to keep it from freezing if it were to get moisture in it from short trips in the winter), and NOT an actual electrical 'ground strap'.
