!AIR, what to do?
!AIR, what to do?
When I remove all the AIR junk on my ride what do I need to do. I'm going to disable the SES code with my HPTuner so thats covered. How about the vacuum lines, can I just plug them up or should they still be connected in some configuration??
Originally Posted by TheBlurLS1
is that whining sound that comes on when i start the car the AIR pump kicking on? it does it when its cold so im guessing thats what it is.
That's what she said...
well that crap has got to go, way too loud. im bout to pull its scholarship lol. ill prolly get my uncle to build me some billet block off plates for the exhaust or somthing. is the pump behind the driver headlight? if so then i guess it has some lines or somthing running to the cats????anyway demo work is my specialty
yeah its behind and below the drivers head light. Its easy to pull just start with the pump and pull all the wires. I also had to plug the vacuum line that was left over by the rear of the intake.
Originally Posted by Raptor99
You only save like 15 lbs.
If it's (ie: EGR and AIR combined) really that much weight total then I might just do it as well.
Well, my air pump died, so I'm just gonna take it off rather than spend $200 on a new pump. Gonna pull the EGR off as well cause I'm gonna run L/T's and no cats soon anyway.
