12:1 CR... What starter?
Old 03-28-2013, 12:08 AM
lemons12's Avatar
Default 12:1 CR... What starter?
Just got my 370 build complete.. I took started it several times and put roughly 50 miles on the car since completed.
I did a few small things, installed nitrous, hid some wires, etc... Went to load the car up on the trailer for a tune... No go.
The starter gear shoots out like it is going to start but doesn't turn the motor over.
We took the starter off and put it straight power/ground and it shot out and spun. I don't think this means that the starter is good though??? If it does, it would make me think it was a bad ground/etc somewhere... However, only one ground was removed and I have double checked it, it is good. The battery is also good and was swapped for another one.
What are you high compression guys running for a starter?
The starter that went out (I think) is a CVR? high torque starter. Hasn't been on the car all that long. Have NEVER had an issue out of the starter before this.
Thanks
Old 03-28-2013, 04:51 AM
supergt99's Avatar
stock starter here. the fact that you started it several times and then suddenly it didnt start, maybe the starter went bad?
Old 03-28-2013, 09:38 AM
Grr
Grr's Avatar
Starter is shot then. Stock pickup starter from napa here $170. Spins over my 14:1 motor without issue. Make sure it is the one with 2 long bolts and not a short and long like the stock f-body starters or you WILL break the block eventually
Old 03-28-2013, 12:41 PM
Full-Force's Avatar
These starters on our engines are hi torque starters anyway. Yours is toast
Old 03-28-2013, 04:23 PM
lemons12's Avatar
Ended up buying a reman lifetime starter... IIRC it was a 2003 6.0 truck starter. Nice looking starter, it has the two long bolts as well.
It was 14X-150X$.
Started up the first key turn and sounds better than the other one.
Thanks for the input guys.
Old 03-29-2013, 06:06 AM
RezinTexas's Avatar
glad you got it sorted. I'm running a stock truck starter on my 11.4 CR motor and it does great as well.
Quick Reply: 12:1 CR... What starter?
