Obx itb
look out for the OBX copy of the Jenvey itbs for the LS1-Ls2 -Ls6 they stick when they get hot .I had a set to test and after ten pull they would start to hang up .
Do your home work before you spend your cash
OBX have a copy of most of the Jenvey set ups and they get you with the price but know this Jenvey buy in the copy's and test them .I also jet them and try them out then smash the with a hammer after the test they use a cheap alloy to make the and they expand and stick also the TPS is the next problem they have .you only get what you pay for
The Scammer Hammer
What?
Let's try this again. OBX seems to have a knock off of most of Jenvey's Products. They attract you with their pricing; however they have sub-standard quality. Jenvey in fact buys and tests OBX knock off parts and the end results are always the same. They perform less that expected for something that appears to look halfway decent. the cheap alloys they use changes shape and causes the Butterfly to stick. they also have a problem with their TPS.
yes you can but it will cost a lot of time and money .They do fit well but they just stick a lot and this will drive you mad on the street
