want to quiet down my trumpet of an exhaust
Old 04-08-2013, 05:28 PM
ryangtp89's Avatar
Default want to quiet down my trumpet of an exhaust
Well i dont care to make my car quieter i really just want to get rid of the trumpet sound it makes, , i just want to get rid of the annoying trumpet sound it makes after 1800rpm. my set up is TSP 1 7/8" longtubes, tsp ory pipe, and LM2 catback, Now would it get rid of that annoying trumpet sound if i got one of those slip fit spun cats ? i dont feel like spending another $350 on a tsp catted ypipe.
I was thinking this cat ? http://www.jegs.com/i/Magnaflow/642/59929/10002/-1
Heres a vid of my car
Old 04-08-2013, 06:51 PM
DietCoke's Avatar
Put a resonator or chambered muffler in there somewhere.
Old 04-08-2013, 07:13 PM
ryangtp89's Avatar
Soo its ok to run two? Since i have a lm2 on it?
Old 04-08-2013, 07:30 PM
ryangtp89's Avatar
Maybe swap out the lm2 resinator for a magnaflow muffler?
Old 04-08-2013, 07:51 PM
HCI2000SS's Avatar
I pretty much have the same setup OP, but only with a LM1...which is worse actually lol! I am looking for something cheap, and have decided on a Flowmaster merge pipe along with a Magnaflow 14419 muffler. Have you considered that?
Old 04-08-2013, 07:56 PM
ryangtp89's Avatar
I was just thinking about adding something on or swap the lm2 muffler out. Just wondering if a magnaflow bullet will do the trick even though im running no cats.
Old 04-08-2013, 07:59 PM
HCI2000SS's Avatar
I'm sure it will help a little, but maybe not enough on it's own
Old 04-08-2013, 08:07 PM
ryangtp89's Avatar
Soo the magnaflow 14419 is the bullet and 3" is the right size to fit on the loudmouth catvack or ory pipe?
Old 04-08-2013, 08:15 PM
HCI2000SS's Avatar
I'm not sure on the "exact" dimentions but I do know it's very close and can be done. A few on this form have swapped out their LM 1 to this
Old 04-08-2013, 08:49 PM
VandykeT/A's Avatar
Magnaflow will make a huge difference. I had LMIIs dumped before and went to a 4" over the axle with a dynomax bullet in the I and a magnaflow in the stock location. Quietened it down a ton. If you have room I would run two mufflers. If not just replacing it with a magnaflow will tone it down.
Old 04-08-2013, 09:44 PM
z28SSilvest's Avatar
OP yes get the magnaflow bullet and ditch the loudmouth II. They really only sound good with stock headers.
Old 04-09-2013, 12:00 PM
ryangtp89's Avatar
Soo ill pull of the lm2 muffler and get that magnaflow bullet. Now what size will i need to fit the lm2 batback?
Old 04-09-2013, 02:38 PM
SSCamaro99_3's Avatar
There has to be a 1000 threads on this topic.
The sounds you are referring to is a result of the exhaust design. The way the pulses are coming together in that rpm range is causing a resonance. Cats will hide it, a better merge wil decrease it, an different muffler may hide some of it, but the only real cure is a tru dual exahust system.
Old 04-09-2013, 03:26 PM
HCI2000SS's Avatar
You want the 14419 Magnaflow OP
Old 04-09-2013, 04:56 PM
aknovaman's Avatar
Go here and read the first couple pages or just jump to post number 272 for dimensions.
http://forum.grrrr8.net/~stevexkr/Fo...10801&page=28&
Old 04-09-2013, 05:19 PM
Drew WS6's Avatar
I have a hooker CB it's silent.
Old 04-10-2013, 09:30 AM
onefast84's Avatar
I would chang the muffler. I sounds like a glass pack muffler. Put a flowmaster on it
Quick Reply: want to quiet down my trumpet of an exhaust
