LS3 water pump on LS1 with F-body FEAD?
I've searched and searched, but i can't find an answer!
My LS1's water pump is headed out. The engine is swapped into a Porsche 944 and i'd rather have the space on the front of the engine that a later pump like the LS2 and LS3 have. I picked up a new pump off ebay that claimed "LS1/LS2/..." but it is actually an LS3/LS7 pump ('09-11).
It looks like everything is mostly the same and from my research i know it will bolt up, but i haven't actually been able to find anyone who says "i put an ls3 water pump on my ls1 with f-body accessories and here's what i did".
From my measurements it looks like it just needs a 3/4" spacer, but that's another $80, so i thought i'd check here first. The other option is to just return the pump and spend another $80 on an LS2 pump, but apparently the LS3 had some improvements so it seems like it might be worth making it work...
Thanks for any help anyone can offer!
Damn, wish i had known that before! I paid $150 for this LS3 pump. :/
The LS2 pump also requires spacers, but only about 1/4", is that correct? Or moving the pulley out a bit...
LS1TECH & Trucks Sponsor
Our pump won't require any spacers, it works with f-body accessories.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Re: LS3 pump: Eh, the usual...nothing the butt dyno would notice, but apparently it has lower rotating mass, it's a few pounds lighter, and some think it has an improvement in cooling flow.
http://sdparts.com/c-1029509-cooling...C||year%3D2000
The search returns only one electric water pump (Item #: MRG4333). I considered buying that pump but it doesn't appear to fit F bodies?
https://sdparts.com/i-20058398-gm-fa...mp-kitwat.html
https://sdparts.com/i-19935381-gm-12...mp-gasket.html
__________________
