Long Tube Headers and offroad Y o2 sensor problem
I've got a 2002 Z28 and recently took her to a professional exhaust shop to put a full Hooker exhaust setup (Hooker long tubes, hooker mid pipe, magnaflow catback). I now have no cats and have O2 simulators for the rear sensors. Upon getting my car back she sounded beautiful and ran perfect. Well after about 20 minutes of driving the check engine light came on. I stopped at the local O'Reillys and got them to run a scan. It showed up that the front passenger O2 sensor wasn't functioning. Well I took it back to the shop yesterday and got it back out today... they told me the O2 sensor wasn't moving (I suppose they were talking about the voltage not changing) and that it was a common problem with the sensors so they put a used O2 in and it was working fine and gave me my car back free of charge (no check engine light). After about 20 minutes of driving the check engine light pops on again, same thing. I've read on the forums that a few other people have came across this problem after doing a long tube setup with the offroad y pipe. Can anyone tell me any solutions for this? I love my Camaro but when the code comes up my gas mileage sinks horribly. (note: the rear o2 simulators are working fine, no codes about them)
What engine codes are you experiencing? If it is bank 1 sensor 1 or bank 2 sensor 1 then you have a problem with your front O2's, never replace with used parts. Hook up a scan tool and let it run, look at data stream to see which O2 voltage is not changing. I've had long tubes and no cats for years with simulators and have never thrown a light.
join the club lol. my stockers went bad directly after i had my long tubes installed which is common as i read. then i replaced them with denso TWICE and they are still throwing a heater code..maybe its because they sit way down and dont heat up well...i'll just live with it
I'll try to get some new ones and see if that fixes anything. Could it be my O2 extenders though? Because it's the same one every time. I dropped like 600 dollars in labor at the exhaust shop so it'll be a bit before I can scrap up the cash to do anything so I've just been driving it for now, will that hurt anything doing such? She seems to run alright, a little worse on fuel but no misses from what I can tell.
Moderator
You're going to have to live with the heater codes
unless you can defeat the heat-loss problem. The
code is indicating that the sensors can't be counted
on at low gas flows. The outcome will be some
mixture error, probably varying a lot with weather
and recent driving history, at the low end.
The trimming error will push you rich and depending
on how you roll into WOT, will push a varying amount
of undesired enrichment.
I've got the same problem. I've drove my car for about the third day after getting it back from the tuner and check engine light is on saying readings for the 02 sensors in bank 1 and 2 are too far off to read or the 02 sensors are bad. I'm guessing they both wouldn't go bad at the same time. I'm running a catted y.
I have been in contact with my tuner about this, in my case since both sensors are throwing codes p1133 and p1153. I think your tuner should be able widen the parameters that you sensors work in and get it to not throw a light and work correctly.
Formally Simplɘ Jack
That's crazy, I thought it was just me. I also just put LT's, ORY, tune and they even put two new Denso o2 sensors last week. Couple days ago my SES light came on and got it checked, stating bank 1 is lean and o2 sensor low voltage or something (P0171 P0131). Going back to Speed, Inc. today to have it checked. So this is a normal problem after header installs?
