Raising Compression Question
Old 05-05-2013, 09:58 AM
crimson-coast's Avatar
Default Raising Compression Question
im building a N/A autocross camaro. currently cammed(.605 lift) and ls6 heads. but I'm thinking of raising the compression to maybe 11-1 or higher. either milling the heads or changing the pistons. anybody do that? and what were the results?
Old 05-05-2013, 10:12 AM
KCS
Moderator
KCS's Avatar
What's your question? Are you asking if anyone has milled their heads or used a dome piston to raise compression, and what happened as a result?
Short answer is yes, and it made more power.
Old 05-05-2013, 03:18 PM
yea i figured. im looking for what setups used. cam specs, injectors, heads used on what block. and seeing what difference it made
Old 05-05-2013, 05:45 PM
Blackpanther99's Avatar
Just milling the heads will bring up the compression and of course more power.
Old 05-05-2013, 06:16 PM
WS6ICK2k's Avatar
Check out the internal section. I highly recommend the new tick cams.
Old 05-05-2013, 06:20 PM
BAD2theBONE's Avatar
I also plan on going with Ticks Performance on my build. Talking to Martin about mine now
Old 05-06-2013, 12:24 AM
ill have to check them out. iv been reading up on gmhp mag about the sti killer. and its made me want to change from drag to autocross. but i have to change my rear gears, my cam, mill the heads. just want to get it where its a beast in the corners, with lots of torque in the low end
Quick Reply: Raising Compression Question
