Header gaskets
Originally Posted by BLOODTA
I'm putting headers on my 2000 LS1, do I need new header gaskets or should I use the stock gaskets that are on the car now?
Jegs' part # for the ones specific to the LS1 is 760-66032 and they cost $34.99 per pair. Worth it if they prevent leaks, and leaks are a common problem with most headers on LS1/6 heads. Spend the extra money, you will thank yourself later.
you can use the stock gaskets.... i have done it 2 times on my car...
many here do the same.. they are metal.. just take a look at them and make sure that they are in good shape.
If not just go to a GM dealer and pick up a new set, they are like 20bux or so. I dont recommend you use any of those Paper/rubber gaskets that they send with new headers.
