looking for parts list
does anyone know of a place where i can find the names & part numbers for all the stuff in the engine bay, along with a photo/diagram of them? i need to replace some hoses/connectors/vacuum lines, but don't know what the parts are called, and it's hard to search for replacements without knowing what the hell the part is.
more specifically, here are the main parts i'm looking for...
pic 1) this one is on the driver's side of the car, and i think it slips into the rear of the valve cover. i can't tell if this piece is broken near the bottom of the connector or not, or if that's just a foam insulator that kinda sticks out the bottom (the gray part that's in between the yellow & the black). the right side of this pic shows the actual part, and the right side shows the connector that plugs into it & where it is on the wiring harness...the 3 circular grounding connectors are the ones that bolt to the back of the driver's side head, and the connector for the part is just to the left of them.
pic 2) i need to find out the part# and/or name of the plastic hose/connector that attaches to this part, i don't need the part itself...obviously, it is snapped in two, which happened when the intake manifold was coming off. the other half of this tube/hose is connected onto a circular black piece that is just under the cowl on the driver's side, in between the driver's side head & the cowl
pic 3) this part connects somewhere toward the front of the intake manifold, near the throttle body...what is this, and does anyone have a part#?
OK, so after a LOT of reading/searching, i've found that pic #1 is the oil pressure sending unit (part#: 12562267), and pic #3 is the PCV valve that's connected to the stock-style PCV hose assembly (which i will be replacing with the NEW-style LS6 valley cover with the PCV valve system integrated, so i don't need the external valve (part#: 12577927).....but i still have not been able to locate the hose/tube that coonects to the piece in pic #2...anyone?
