What did I just screw up???
During the header installation I jacked up the engine without disconnecting the power steering hose and dumped PS fluid everywhere. It is in my alternator as well... not sure what I need to do about that.
So I am finishing up my header install when I notice that during the engine jacking I must have ripped this sensor apart. I need to know what it is, how much it's going to cost for me to replace it, and how I need to go about replacing it.
Thanks in advance!
EDIT:
It appears to be the engine coolant temperature sensor according to: http://www.ls1.com/forums/f6/list-se...hey-do-159572/
Does anyone know where I can get one?
Thanks in advance!
EDIT:
Is this what I need by chance???
Strike that, looks like this is what I need:
http://shop.advanceautoparts.com/web...erature+sensor
The wires on the plug are fine, the clip pulled out of the sensor so it will just require me replacing the temp sensor and I should be good.
Any tips on the alternator? PS fluid didn't drench it, but I'm pretty sure that some did get inside. Is this something to worry about or will it be ok? Also should I just go ahead and try to clean it with some carb cleaner or something?
Thanks!
Yea, the workmanship and fit seems to be absolutely perfect. I'm crossing my fingers for no leaks lol. Just have to put belts back on, fix my sensor, clean the PS fluid off everything, change oil, remount coil packs, install new plug wires (MSD 8.5), and install new O2 sensors and I should be ready to test it.
God I hope everything works lol.
