Installed 160º stat, Meziere EWP, changed fan settings, yet it still reads under 210º
If you have autotap or something similar your suppose to see closer readings. Thought you would know by now that the stock temp gauge is a dummy. It just lets you know if your temp is hot or cold. lol Someone here posted they are workin on a solution by converting the 99-02 gauge to a 98. Still havent seen it. Good luck with it with those mods I would be more sure the engine is running cooler.
I'm sure you are running cooler. I put in a 160 and adjusted fans. I used my scanner when driving and I'm running around 172 - 177. But gauge reads just to the left of the 210 mark. Fan 1 on at 184 off at 175 Fan 2 on at 194 off at 185. What do you think of your EWP? Was it worth it?
