drilling my TB?
drilling my TB?
once i get my verter in i am probably going to need to drill the TB so my idle will be better. could someone give me a heads up on what i should be doing? where i need to drill? drill bit size? things to look out for ? u get the idea.....
thanks J
thanks J
thanks J
thanks J
ttt
take off the t-body and you will see a small hole in the center. you will need a set of drill bits that have sizes from small to larger in order. find the smallest bit that will fit in the hole with no problems,then go one bit size bigger and drill the hole. it will not make it much bigger,but don't do too much at first. if the car still dont idle as you wish,then go to the next bit size and drill it again. keep going till you get what you want. you should not need more then two or three sizes bigger. put some grease or oil on the end of the bit before you drill,for lube. make sure all shaveings are gone before re-installing the t-body. hope this helps goodluck to ya man.
thats what i was thinkn. just start small and go up. i give it a try. theres only 1 hole to drill right?
Originally Posted by foff667
fwiw i didnt have to alter anything after my tci install
i kno. im hoping that i dont haveta, but knowing my luck i will have to.
3/32 allen wrench for the screw
hmmm mine doesnt use an allen wrench...not sure what size it is either I'll have to check.
i heard that on 98-00 use an allen wrench. what kind of wrench are you using now?
