new ls1 owner 2000 ss slp
Old 10-19-2013, 11:26 PM
madman21's Avatar
Default new ls1 owner 2000 ss slp
Just got one whats the best mods to start out with.Going to use it for little drag raceing but want it to corner good.
Old 10-20-2013, 08:53 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Welcome to LS1tech! SEARCH will be your best friend around here!
Old 10-20-2013, 09:01 AM
arock24's Avatar
The best place to start is usually the suspension. You can have all the power in the world but it's useless without traction. If you have stock parts, depending on mileage, you may need to replace your shocks/springs already (personal recommendation is bilstein shocks (which you have), with Strano springs. After that, sub frame connectors should be your next step. As said before though, the search will help you find all the answers to your questions.
Old 10-20-2013, 09:22 AM
2002ss335's Avatar
I agree with arock24 cars that old have suspension parts that will be worn.
But the first thing you should do is get some seat time before trying to play "Speed Racer". It seems like every week there is a thread that has the line "I was just going...." and now they have a parts car.
Good luck with your new ride, and when you are ready look here:
https://ls1tech.com/forums/new-ls1-o...anna-fast.html
Old 10-20-2013, 04:25 PM
Blackpanther99's Avatar
Id focus on suspension parts first. You can start with normal bolts on also. Is yout car a M6 or A4? CAI, Long tube headers and full exhaust is a common start. Then go on from there.
Old 10-20-2013, 09:49 PM
Lucas88's Avatar
I went with sway bars right away. Reduces body roll huge! I can still fly over speed bumps, have s smooth ride, and not sacrifice ground clearance. Easy install. Great ride.
Old 10-20-2013, 09:50 PM
Lucas88's Avatar
Sway bars
Old 10-22-2013, 07:54 PM
Flawless02SS's Avatar
SFC's (sub frame connectors) are a must
Old 10-22-2013, 11:58 PM
99Bluz28's Avatar
I'd go with a good set of shocks first(Bilstein , Koni STR.T or Koni SAs) , then hollow swaybars(strano), an third SFCs (weld-in, 2 point).
Old 10-23-2013, 12:53 AM
mean_greenZ's Avatar
Start with basics. Make sure everything is in good working order. Get used to the car first. A lid, longtubes, and tune help out a lot. If it's a M6 then a good aftermarket shifter and rear gear go a long way.
Quick Reply: new ls1 owner 2000 ss slp
