fast rails help
fast rails help
Anyone that has installed fast rails on a ls6 intake or stock intake can probably help me here.
Looks like the back of the driver side rail is contacting the throttle cable bracket that's mounted to the rear two intake bolts.
I'm assuming ill have to pull the intake to remove the bracket but just wanted to ask first. May back the bolts out as far as the cowl will let me and try to cut the braket off.
